Can someone explain strat switch or "mid shift" mo
markmalin
Post by markmalin »
Actually, just a simple diagram on how to do it would be great.
Mark.
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
heisthl
Re: Can someone explain strat switch or "mid shift" mo
Post by heisthl »
some like an .02 better than a .05 or .047
www.RedPlateAmps.com
markmalin
Post by markmalin »
heisthl wrote:some like an .02 better than a .05 or .047
Thanks Heisthl.
Mark.
@MalinAmps
markmalin
Post by markmalin »
So it's just switching between a 0.01 and 0.047, eh? This is what's called the "strat switch" or "mid shift" mod?
Mark.
@MalinAmps
mlp-mx6
Post by mlp-mx6 »
Yep - it is very simple, and very effective.
Me: Just one more...
So which value works with a strat the best, the .047uf?
markmalin
Post by markmalin »
mlp-mx6 wrote:Yep - it is very simple, and very effective.
I just did the mod (temporarily). I didn't have a PS orange drop 0.047, just a 715 O.D. It's not terribly noticeable... but it IS Christmas Day and I'm playing "honey will you keep it down" volumes. I do notice a difference, just not that substantial. Should it be that substantial at low volumes?
Also, does this have more of an effect as you rotate the mid control, or is it accross the Mid band??
Mark.
@MalinAmps
mlp-mx6
Post by mlp-mx6 »
My experience with my non-HRM is that I simply (yet dramatically) prefer one setting over the other with single-coils versus humbuckers. It just sounds "right" on one setting or the other - never on both settings.
markmalin
Post by markmalin »
mlp-mx6 wrote:My experience with my non-HRM is that I simply (yet dramatically) prefer one setting over the other with single-coils versus humbuckers. It just sounds "right" on one setting or the other - never on both settings.
Just curious -- did you go with the 0.047 or the 0.02 as the alternate cap? Heisthl mentioned some people like 0.02 better than 0.047 or 0.05
Mark.
@MalinAmps
mlp-mx6
Post by mlp-mx6 »
.01 & .047 are in my circuit.
Do you guys use shielded cable to the switch to do this?
heisthl
Post by heisthl »
I don't but the few times I've done it I've always had the switch fairly close to that area of the board. The last couple of times I've done it I used a .047 in series with a .02 (yields .014uF) so I can just short out the .02 to get the .047.
Clever! 8)
jazzcat
Post by jazzcat »
Does this switch work with a HRM Version too?
