Remember that pedal page? Dumbleator added, clip
Bob-I
Post by Bob-I »
I decided to try my hand at a preamp in a small chassis. I had this old chassis with lots of holes in it so I simply built a turret board and put 2 tubes in it. No switching, no extra tone stack switches, just a Hybrid preamp. I used Doug Hoffman's tube pedal power supply which works really nice.
Here's the schematic. I'll try to get some pics soon.
[img:1345:641]http://www.patmedia.net/bob-ingram/JPEG ... ematic.jpg[/img]
Still tweaking. The treble control is not as effective as I'd like, meaning somethings killing the highs later in the ckt. Also the output is too hot so I'll be adding a voltage divider to reduce the output. I currently using a 12VAC 1000ma wall wart to power the torid. I get 12VDC for the heaters, regulated and about 310VDC for the B+.
Once I nail the tone it'll be easy to move this to a new chassis.
pedro
Re: Remember that pedal page? Dumbleator added, clip
Post by pedro »
Looks very interesting Bob.
FWIW, I ordered a Zendrive from Alf Hermida, waiting for shipping charge, but Alf also recommended the BSIAB 2 pedal ( Brown sound in a box ) . I think I'll build one and see whats it like with Dumble clean channel.
http://www.generalguitargadgets.com/ind ... Itemid=178
regards
Pete
Icetech
Post by Icetech »
Why cant the dumble OD channel be made to sound how people want to sound with these pedals?
Bob-I
Post by Bob-I »
Icetech wrote:Why cant the dumble OD channel be made to sound how people want to sound with these pedals?
My thought exactly. I think it's pretty close but I'll need to spend some time with it to be sure.
pedro
Post by pedro »
I think the idea is to find a pedal that can get close to dumble sounds when your not using an ODS or similar dumble amp.
Robben Ford uses the Zendrive or mosferatu when hes not using the Dumble - say into a clean fender.
Cant see any need to use a pedal with the OD channel on a Dumble !
cheers
Pete
Icetech
Post by Icetech »
ahhh k... i understand that then:) i have always just had a thing against pedals... just like a guitar and amp.. although those pedals sound amazing...
I need to rework my amp for a little more gain in the OD channel, right now im using the od network layout from norms ODSreverb, i need to put in the one that uses a pot to adjust...
Bob-I
Post by Bob-I »
pedro wrote:I think the idea is to find a pedal that can get close to dumble sounds when your not using an ODS or similar dumble amp.
cheers
Pete
Exactly. The purpose of this preamp is for use with other amps, not with the Dumble.
Robben often brings these pedals and uses a rented Fender amp.
Icetech
Post by Icetech »
No prob guys.. i am just lost in dumble land.. couldn't figure out why you would need that pedal:)
HiGain
Post by HiGain »
I've been wanting to try this for a long time. I've built several dumble inspired preamps with fets, with pretty good results.
So, does your's sound like the overdrive channel of a dumble?
Jake
Bob-I
Post by Bob-I »
HiGain wrote:I've been wanting to try this for a long time. I've built several dumble inspired preamps with fets, with pretty good results.
Jake
It does, when it's plugged into the clean channel of a Dumble. Into a Fender it's a bit scooped in the mids and a tad bright.
Also, I think if I can lower the output impedance a little it'll match better. Any suggestions?
pedro
Post by pedro »
Hi gain,
how do your fet preamps sound ?
I'm gonna be waiting ( for a long time I think ) for a Zendrive I'm trying to order, but I guess its a cascaded mosfet design with maybe a dumble style post OD tone shaping EQ.
would love to capture that dumble OD sound at low volumes with a pedal.
Doesnt beat the real thing - tube amp running nice and open, though.
cheers
Pete
Bob-I
Post by Bob-I »
I recorded some with the preamp today, plugged into my Weber kit Super Reverb, all tone controls on the amp set on 5. It doesn't sound much different than a fuzz pedal to me.
http://www.patmedia.net/bob-ingram/Music/test.mp3
I'm thinking I'll test it directly into the PI of the same amp, but I'll have to open the amp up as there's no loop.
HiGain
Post by HiGain »
Cool!
See attached image for some ideas.
Jake
HiGain
Post by HiGain »
Hi gain,
cheers
Pete
Hi Pete,
It actually approaches the tonality, and a little bit of the feel, but I've never played the real thing (just some clones). I'll try to do a recording in the next week or so. I'd certainly recommend you give it a try, though I'd use JFETs instead of MOSFETs, since you can bias them more easily. Also, if you follow the dumble topology, MOSFETs will give you way too much gain. Shoot me an email if you want some help with this. I have a fair amount of experience, though limited electronic understanding. :wink:
Jake
Bob-I
Post by Bob-I »
Cool!
Jake
I appreciate the ideas, and I might try them, but I want to try to stick to strictly tubes in the signal path.
