Dumbleized twin reverb problem
kyle31
Post by kyle31 »
I recently dumbleized my twin reverb. The clean channel works perfectly. I actually like it more than I liked the twin. I also removed the reverb and vibrato.
The overdrive circuit works and sounds ok but my Level pot does not work. I can turn it 0- 10 with no audible change. The only way to change the gain is the trimmer.
I have tried 2 pots of different values (100k and 250k) and nothing has changed.
Any ideas what the problem could be?
Bob-I
Re: Dumbleized twin reverb problem
Post by Bob-I »
kyle31 wrote:I recently dumbleized my twin reverb. The clean channel works perfectly. I actually like it more than I liked the twin. I also removed the reverb and vibrato.
Pics would help but it sounds like a grounding problem.
kyle31
Post by kyle31 »
The pot lug that's supposed to be grounded is definitely grounded.
Bob-I
Post by Bob-I »
Pics?
ic-racer
Post by ic-racer »
I had a lot of little problems like that on my Super Twin conversion. Mostly circuit or wiring errors. I just went through the portions of the circuit in question and traced it out, wire-by-wire, comparing to the schematic.
