Is it possible to unwind a power trans to lower voltage ?
I have a large collection of beefy iron and most of my voltages are pretty high in the 340-340 to 410-410 range for big octal tubes of old PA amps and old wall voltage. I would like to reuse these beasts but other than fitting these amps with Dana's VVR or a ridiculously expensive zener, could I unwind the HV secondary on these old transformers ? I don't know if that winding tends to be the first or last to go on but has anyone done it ? Is it practical or another weekend lost ? I found nothing in my searches so it must either be obvious or I'm the first one to think of it.  Probably the former.
						Re: Is it possible to unwind a power trans to lower voltage ?
I have been wondering the same thing for a long time.  I am guessing that if the high voltage winding is the last one on the bobbin, then it might be possible if it is a single winding meant for a bridge rectifier.  Otherwise you would have to unwind to the center tap, take a bit off, then wind back on the other half to match the first half.
I see, good point about the rectifier and center tap. I guess that the sec. would have a monster amount of turns to unwind to get to the CT, even if it was the last winding.
Thanks.
						Thanks.
You can always add a series transformer with the secondary in phase or out of phase to boost or to buck, unwinding is a pain since you need to undo all the laminations
Hi there,
here is a link to a circuit that will allow you use inexpensive parts
to achieve voltage reduction.
members.optusnet.com.au/eyes.only/vj_mods_3/Zener2%20Lower%20B+.pdf
cheers
paddy
cheers
paddy
You could also build a choke input power supply to drop your voltages down, tho it will require a hefty choke that can handle your original high voltage. Perhaps combine that with a tube rectifier with a big voltage drop to drop it some too.
What kind of voltages are you looking for? Your 340-0-340 PT will yield about 480 DC when rectified and a 5U4GT rectifier will drop about 44 volts per side, so that would give you about 392 VDC... about perfect for a Wreck... and you can drop that further with a choke input filter supply...
Could you use an internally adjustable VVR circuit to tune the voltage to any desired value?
That's the direction I'm going. Thanks.
				guitronics
Lower voltage from Transformer
Just keep it simple and use a wirewound power resistor in series with the secondary.
									I'm mainly interested in Class A Single Ended Amplifiers,although switchable NF would be OK.
You can use a cheap zener and add a powerful transistor to pass the wanted current. Transistors are cheap.chopstuck wrote:I would like to reuse these beasts but other than fitting these amps with Dana's VVR or a ridiculously expensive zener,
I would just increase the first dropping resistor to bring them all down.
