Buffered FX loop on D'Lite...
hairyandy
Post by hairyandy »
Hey all,
I've been thinking about adding a buffered FX loop to my D'Lite 44 build. I know the usual thing around here seems to be to use a Dumblelator but having another outboard unit just seems kinda dumb to me. Has anyone built a Dumble circuit with a built-in tube-buffered FX loop? I took Bruce Egnater's amp seminar a couple years ago and the buffered FX loop in his JTM/JCM amp is killer! It sounds great and is pretty simple to implement so I thought I'd try adding it to my D'Lite. Has anyone else experimented with anything like this? I thought I'd ask before I jumped in the deep end...
Thanks,
Andy
Re: Buffered FX loop on D'Lite...
I put the Ironsounds FX loop in my D'Lite and it works well.
It has true bypass and a 6 db pad switch.
I have heard it's a serial loop but it works well with time based effects.
( reverb, delay, etc).
Probably not what you wanted to know, I just thought I would throw it out there. :wink:
brownnote
Post by brownnote »
The challenge with a tube buffered loop retrofit is adding the tube.
You can relocate the bias pot, and place it there.
From that point, a number of circuits work well.
umbleator, KOC, etc.
If you're going to buffer it with an opamp, the Ironsounds loop is the way to go.
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
hairyandy
Post by hairyandy »
brownnote wrote:The challenge with a tube buffered loop retrofit is adding the tube.
I've currently got a switch to go between the OT primaries. I find I never use it (sounds much better in the 8k setting) so I'm just gonna put the tube there. I'll have to widen the hole but it should fit I think.
Thanks,
Andy
brownnote
Post by brownnote »
Cool.
Fischerman
Post by Fischerman »
I built my 50W HRM with a tube buffered loop...I just used the Dumbleator circuit (except tweeked the 10k to 27k and the 1k5 to 1k8). Took the power from the screen supply and made a new node...you don't have to use two nodes for a D'Lator like the real thing.
