Dimensions for combo and head
				jazzyjoepass
Anyone has the dimensions of the combo and head style amps?
						Re: Dimensions for combo and head
The combos are 20" height X 20.75" width X 10.25" depth. Heads are under 10" tall, don't know the exact dimension though.jazzyjoepass wrote:Anyone has the dimensions of the combo and head style amps?
Gil
				jazzyjoepass
Thanks Ayan, nice to see you here.
Anybody else got the dimensions for the head?
- Funkalicousgroove
I thought they were 10.25x10x20.75, but I think he uses 15mm board instead of 18mm so they look a bit smaller. I have a friend with 3, I'll measure next time I get up that way.
You may be right. As you know, my cabs are 10" tall, but to me, Dumble's looked shorter!Funkalicousgroove wrote:I thought they were 10.25x10x20.75, but I think he uses 15mm board instead of 18mm so they look a bit smaller. I have a friend with 3, I'll measure next time I get up that way.
Gil
- Funkalicousgroove
interesting querry, I shall have to investigate now!!!
						- ElectronAvalanche
I used these dimensions:
Head cabinet:
Outside length: 20 3/4"
Height: 10"
Depth: 10 1/4 "
Inside length: 19 1/4"
Thickness: 3/4"
Combo:
20" Height
10 1/4" depth
20 3/4" Lenght
Dominik
						Head cabinet:
Height: 10"
Depth: 10 1/4 "
Thickness: 3/4"
Combo:
20" Height
10 1/4" depth
20 3/4" Lenght
Dominik
Here's a copy of the front panel that I've been using. The dimensions were calculated from photos and info on this site. It's 19.25" by 2.25", pots are spaced at 1.40" and switches at 0.6". I know that the typeface is not quite right yet...I'm looking for a better one. Any suggestions/comments for improvements would be welcomed. I can post a corel draw file of the panel if anyone would find this useful
my browser tried to open the last file in quicktime for some reason, so I've posted a lower res (and smaller) version in gif format. I hope this works
				jazzyjoepass
Yeah... coreldraw format would be good ... i see if i can do the fonts and post it back ...
Cheers, some betterfonts would be great, but it might be good to wait a bit, in case anyone can make some improvements on the dimensions.
BTW, the TIF file I posted earlier works, so long as you download it (i.e. save page as ...), it just does not display, at least on mozilla.
here's the coral file in a zipfile. It did not attach otherwise
				jazzyjoepass
I haven't looked them yet. Had problem finding the fonts that was used in the file. Is there anyway I can get hold of them? They seem pretty close to the originals, I must say.
It's been a while since I used Coreldraw, but I think you can create your own fonts in Coreldraw - that will come in handy when recreating the Dumble fonts.
here's the fonts I used, but I needed to squash the block one up a bit to make it fatter. I doenloaded them from a free fonts site, so I guess the're freeware and ok to post here
						- glasman
Ok so does anyone know what the height and width of the oval port on the back of the combo cabinets?
Just curious.....
Gary
									Just curious.....
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
