Bludotone Bluesmaster clip
dogears
Post by dogears »
Hey guys,
Here is a clip of my new Bludotone Bluesmaster. 6L6 tubes, 100W. This is recorded with a cable in the loop instead of the Dumbleator. I will do another with my rack since the amp is tuned for the Dumbleator.
This is a full on Bluesmaster from a to z. Recorded at about 9 oclock on the master. The magic happens at 11 or so... Even still, it rocks here. With the Dumbleator, the master can be turned up and the amp fattens considerably.
http://www.scottlernermusic.com/Bludo/BludoBM2.mp3
stelligan
Re: Bludotone Bluesmaster clip
Post by stelligan »
Very nice....
Bob-I
Post by Bob-I »
Great amp. I played through that one at the show and honestly, as much as I liked that amp, the Blue straight HRM was more my cup of tea. Brandon makes some beautiful pieces for sure!!
dogears
Post by dogears »
This is the Blue Suede one. Do you mean the brown one?
Fwiw, I retubed and tweaked the trimmers. It is a bit warmer now.
Bob-I wrote:Great amp. I played through that one at the show and honestly, as much as I liked that amp, the Blue straight HRM was more my cup of tea. Brandon makes some beautiful pieces for sure!!
Bob-I
Post by Bob-I »
dogears wrote:This is the Blue Suede one. Do you mean the brown one?
I'm a bit confused. The sound I liked was the Brown head into the Blue cabinet. I also liked the Brownnote 100 watter a lot.
dogears
Post by dogears »
Laz has the brown one. Brandon still has the blue cab. To confuse you even more, we swapped the chassis into a plain tolex box for me!! LOL
Fwiw, Andy's new HRM is similar to Laz's circuit except for his layout and smaller iron. The brown Bludo has the biggest output I have ever seen.
There is a kind of upper mid clarity on this Bluesmaster that was not present in the other amps. And, its clean channel when pushed and with the PAB, is unlike any Dumble I have heard. Not sure if you caught that when we did it.
mlp-mx6
Post by mlp-mx6 »
Now THAT is some gorgeous tone!
Me: Just one more...
markmalin
Post by markmalin »
dogears wrote:Hey guys,
Sweet tone. As always, I can listen to your playing all day long ;)
So what guitar were you using, and which pickup and... where did you have the volume set on the guitar?
Mark.
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
dogears
Post by dogears »
These clips are all my Baker RF with a medium hot alnico II style pup in the bridge. About 8.7k or so. I usually have the controls all the way on. I shoudl learn to use them... ;)
Here is a much better clip from yesterday where I got to turn up the amp a little.
http://www.scottlernermusic.com/Bludo/B ... ckFunk.mp3
markmalin
Post by markmalin »
dogears wrote:These clips are all my Baker RF with a medium hot alnico II style pup in the bridge. About 8.7k or so. I usually have the controls all the way on. I shoudl learn to use them... ;)
Man, that's nice. I'm still tinkering with my amp... how high to you have the drive for the OD? Seems like my D'lite gets fuzzy when it's too high, but your tone has so nice and articulate. Granted, different amps, but I'm still learning to use this thing.... hence the questions.
Mark.
@MalinAmps
Tonegeek
Post by Tonegeek »
The thing I notice is the amp is well balanced and articulate regardless of string and fret position. I hear no harshness, spikes or flabbiness. Sounds also like it will sustain forever if you want it to and can get some good feedback. You must be loving it...
Pitcher Amplification
http://pitcheramps.com
Funkalicousgroove
Post by Funkalicousgroove »
It's nice to know that your hard work is going into the hands of a player like this!! :D :D
brownnote
Post by brownnote »
Sounds great Scott!
markmalin wrote: Man, that's nice. I'm still tinkering with my amp... how high to you have the drive for the OD? Seems like my D'lite gets fuzzy when it's too high, but your tone has so nice and articulate. Granted, different amps, but I'm still learning to use this thing.... hence the questions.
Mark.
Totally different beast Mark...the bluesmaster is waaaay different.
To be fair, your amp isn't really a D'Lite...same chassis, similar layout, but different everything else; components, transformers, etc. ...it makes a difference.
Keep working at it though...I think Brandon would agree, a lot goes into voicing these amps, and the things the Big Guy did, were done for a reason...it certainly helps having that baseline to work from when things don't turn out as expected.
Funkalicousgroove wrote:It's nice to know that your hard work is going into the hands of a player like this!! :D :D
Nice work Brandon!
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
markmalin
Post by markmalin »
Mark.
Point well taken, BN. Actually, it's getting closer and I've learned a ton. If I had it to do over again, I'd buy the kit as a baseline (and probably would have left it as-is :), it's my own being pig-headed about not wanting to build a kit. Kind of like with learning jazz -- my wanting to know "why", not just "how", means it takes me longer than most people. Thanks for your patience with me, though! - Mark
@MalinAmps
les_guitar
Post by les_guitar »
Very very nice!
Great tone, great chops!
I love those bluesmaster bludo's!
