I'm putting together a Mouser order, and I'm curious what you guys are using for the bias pot... any recommendations?
Has anyone every just used a regular 25 k Alpha pot and mounted it to the chassis so you can adjust bias from above the chassis?  Would it be heavy enough; ie able to handle the wattage required?
						Bias pots
				tubedogsmith
Re: Bias pots
I use a PEC 2 watt locking pot and it works great.
Re: Bias pots
I used a Bourns multi turn. About $12 at my local electronics shop I believe.
				bentonar18
Re: Bias pots
Guys, thanks.  The Bourns you mentioned:  what wattage is it rated for?  Do I need to be concerned about wattage here; will 1/2 watt ratings be enough?
I went back and dug through my NOS supply of Allen Bradley pots my dad gave me (bless you, dad!). I think I have some AB's that are pretty close to the PEC style with the locking threads, but I don't know what they are rated for. They are "Type J" pots with a locking top: the part number on the back is JU-5031. It's roughly a 50k pot; would this work?
Man, I'm getting close to having all my parts together: got the trannies last week, got a Komboking chassis about a month ago, built up my board last week, and recieved my Mouser order last week. I think the last thing I need is the bias pot! I'll try not to get too excited...! thanks
Re: Bias pots
1/2 watt should be fine...
