 I am posting this here because you guys seem to have the market cornered on hum reduction. There are plenty of amp building furums on the net that I frequent, but you guys seem to be the "top dogs" so to speak!
First, a little background. I dove into my first amp build a couple of months ago. Knowing I wanted to tackle something easy to start with, I decided a single-ended Champ or Princeton style circuit would be the way to go. The Hunter Two-Stroke is a nice evolution of these basic circuits, so I decided to start with this basic circuit design.
I thought hard about a kit, but in the end decided to build from the ground up. I decided the build format (turret strips), the circuit layout, the chassis size, location of controls, faceplate design, head cab material, shape and design, tolex, aesthetics, and sourced all components. It is pricier this way - because I also had to buy the necessary tools and equipment. But I'm getting so much satisfaction with the finished product - which is almost totally unique. Only way it could be more so is if I designed the circuit! Maybe next time. Anyway, I digress. The negative aspect of the ground-up approach for a novice has unwittingly bit me in the a$$. That problem is HUM!!!
There is measureable 100hz hum (I'm in Australia - 240v 50hz) that is always present from power-up (no standby switch) and does not vary with the volume control. It is always there, always the same volume. It is also there even if I pull the single 12AX7 preamp tube. If I strum a cord and throw the power off, the hum stops instantly while the volume diminishes slowly. The hum is not unbearable, but it is loader than any of my other amps and I can hear it in the next room. So, to me it is too loud.
Anyway, those are the symptoms. I've done a fair amount of rewiring and rerouting. I believe the problem is poor grounding throughout - I used an aluminum Hammond chassis and did not follow star or buss grounding techniques. I just grounded to the chassis thru whatever turret lugs were nearby. My next step is to begin redoing my grounding system in accordance with many of the great references on the Net (i.e. Aiken and others floating around). But, I figured that a pic of my chassis and wiring here might help save alot of work that might send me to an early grave.
 So, here are a few pics. Does anyone see anything obvious before I tear this thing apart???
[img
[img
[img
[img
[img
[img
 I had thought that the HV CT was merely a "reference" like the heater CT.
   I had thought that the HV CT was merely a "reference" like the heater CT.   Now there is no hum and the tone is super fantasmo.
    Now there is no hum and the tone is super fantasmo.   I hope you get your hum issue sorted out. Interesting though how Dave Hunter morphed the two-stroke into a one-stroke...
