I've noticed that on several Express layout graphics (including Nik's), the power switch has 6 tabs on it, indicating a DPDT switch.
Looking at the wires in the Francesca pics, the schematics and some common sense, it seems to me that it should infact be a DPST switch.
Am I smoking crack here??? See attached pic...
In the same pic I notice that KF used some really light gauge wire for the pilot light- any clues about what gauge?
Thanks in advance!
Ron
Express Power Switch
- Ron Worley
Re: Express Power Switch
It's probably heresy here, but IMO, you can skip the varistor and use a SPST like every other amp and only you'd know. Mine has a SPST. Shhhhh. Don't tell anyone. As I understand it, the varistor is there for surge protection.
You can probably use just about anything on a pilot. I'd guess 22 or 24 ga would work just fine. It's a tiny bulb. What could it draw? 1W? I use 20 ga solid because that's what I wire filaments with and it's on that circuit.
