hafler t2 preamp
hafler t2 preamp
hello,anyone know what the tt2/d.o.t.trans?is on this schemo and what its purpose is.i bought this on sleeze bay and it is missing and replaced with a couple of resistors.any thoughts would be great thankx
						Re: hafler t2 preamp
It's a transformer and it's used as plate load for T2B and as a decoupling stage to low voltage following stages. R23 is a local feedback loop.
Replace TT2DOT with a 100k to supply and a 47n 630v to R24.
If you noticed too much bass, use a 22n, if not enought bass, try 100n.
Happy to feel you satisfied at the first run!
If you want to try to "mesallize" the sound, try a small cap (100 to 470pF) across the 100k.
