I'm looking for options/suggestions for multi-pin footswitch connectors. Looking for 4-6 conductors. Want it to be removable at both ends (amp and footswitch) without being too bulky.
So far I'm considering multi-pin XLR type or RJ-45 connectors. Suggestions? Smaller/compact is better.
Multi-pin Footswitch Connector Suggestions??
Re: Multi-pin Footswitch Connector Suggestions??
Two options:
(1) 5 pin DIN connector. You can use the marshall style which is splyed out a bit, or use the common audio style which is used on MIDI connectors.
(2) Mini DIN connector. Avaliable at mouser, digikey etc. Can get up to 9 connectors incl ground.
d2
d2
For sturdiness I like the XLR type. However, if you use a standard cat-5 cable, you can buy replacements anywhere and in multiple lengths.
--mark
--mark
I think you've really already got the two most viable options... XLR and DIN.
For XLR, there's a 5 pin version which is often referred to as DMX and is used in stage lighting control. You may find it easier (and cheaper) to locate a DMX cable than a 5-pin XLR. This system is obviously sturdy and 'pro' but the downside is the chassis mount connectors are quite bulky.
On my last build I used DIN connectors (5-pin 180 degree female on each end) and a standard MIDI cable to interconnect them. Nice because MIDI cables are cheap, available in may lengths and offer 5 conductors plus shield.
+1 just buy a spare for when a stage challenged funster steps on itodourboy wrote:
Thanks for the tips.
I think I'm leaning towards Cat-5. I like the easy to replace anywhere/anytime thing. Neutrik does them with an XLR type housing for durablilty. The only drawback to the XRL type is finding a socket that will easily fit in a small footswitch box.
Is there a 5-pin DIN socket with some sort of lock mechanism that will still work with a standard MIDI cord in a pinch?
Deric®
There is a 5-pin DIN with a latching clip that keys into a corresponding DIN socket (similar to an XLR latch). These are definitely compatible with regular DIN connectors. A lot of MIDI leads seem to be latching actually.
There's also a better twist-lock variety but I can't remember offhand whether they're compatible with normal plugs. I think they might be, since the locking ring sits quite proud of the connector.
After a bunch of digging thru web-sites and catalogs, I think I'm going to go with Neutrik Cat-Con RJ-45. It has the durability and solid locking connection of XLR type plugs and the ability to work with any standard RJ-45 cable in a pinch.
Thanks for the input!
Deric®
