Been interested in the Micro designs on Robinette's page, where you get 1 or 2 watts out of a 12AU7 wired push-pull into a Fender-style reverb transformer… and since I'm also curious about the "cascode" sound, I thought I'd try marrying the Micro power section onto a cascode preamp section.
Here's a first draft of my schematic – anything I should look out for?
Some questions in particular: I'd like to include a Vox-style Cut control, but I'm not sure if that will work with the Trainwreck Type-3 master volume. On the B+ rail, I've just pencilled in my dropping resistors and noted the voltages I'd like to achieve. Was planning on tweaking once I've got it fired up and can take measurements ... but let me know if the values look way off! Also, not certain what the "ideal" B+ voltage is for a cascode design. Any recommendations?
Thanks all
