Transformers for Modulus Rocket
jdscustomshop
Post by jdscustomshop »
Apologies if this is too novice of a question, but I’m doing a Rocket build based on the Modulus “Wrocket” but with the Heyboer OT/PT instead of
HTS-9144 PT
HTS-8083 OT
The Modulus has 16uF x3 and 30uF x2 and PS dropping resistors of 10K and 22K 3W. I’m sure the PT/OT modulus provides is fine but with the Heyboers, would this create any issues?
Littlewyan
Re: Transformers for Modulus Rocket
Post by Littlewyan »
Are you asking if these transformers will fit the Wrocket chassis? If so, has the chassis been drilled for transformers already?
