I have a Partridge PT supposedly from a SC200, and the secondary windings and voltages it mostly check out as expected - but the three big wires (black, blue, green) coming out of the secondary, which one would assume are the heater winding, measure ~62VAC across two pairs and ~3.1VAC across the other. I double- and triple-checked the readings (it's an auto-ranging meter, so the only setting is "VAC", and the decimal point is clear and obvious).
There is a separate bias winding that provides about 42VAC.
Any of the three wires measure open to any other winding wire.
The black wire is solid core, the other two are stranded.
I confirmed I'm supplying mains power to the correct primary winding (the other windings autoformer to the expected other voltages).
Any ideas why this would be? I know unloaded windings always read higher than nominal but 10x seems excessive!
