Which wire gauge sizes would  be used in the actual construction of  push pull output transformers and power transformers?
Thanks.
						Wire Gauge Used In OP & PTs?
Re: Wire Gauge Used In OP & PTs?
I am not saying this to be a smart Ass or mean, but If you have bad  ones you want to try to rewind and you need to ask this question then you should not be considereding rewinding them.
- johnnyreece
I would direct you to a similar thread you started in August:  https://ampgarage.com/forum/viewtopic.p ... 61#p443861
