Steel String Singer preamp power transformer
				the_jessmo7
Hey guys! I want to build a Steel String Singer preamp (minus the reverb) to run into my DAW and use speaker sim. What power transformer would work for running three preamp tubes at proper voltage?
						Re: Steel String Singer preamp power transformer
Same project is on  my list of builds. I've been using Antek for all my preamp transformers.
between the as-240, as-280 and as-320 all my preamp needs have been covered. they have 2 secondary hv taps and 2 6.3v taps at 2A each.
I've used this trannie on multiple builds using 5 12ax7's. wish they would trim about 1/4" of the width so they could be used in 1U racks too though
https://www.antekinc.com/as-05t240-50va ... ansformer/
