safety check on Trimmer
angelodp
Post by angelodp »
Hi I have 10KO17M PIHER trimmer in there for the PI tube on an AB165/864
I am not sure about the rating of this trimmer since its seeing B+ at above 400VDC
If any eyes know this timmer can you confirm or reject this component.
Thanks A
pdf64
Re: safety check on Trimmer
Post by pdf64 »
The 400V isn’t across the trimmer, right?
The max voltage between any of the trimmer terminals is what’s relevant to its voltage / power limits.
Roe
Post by Roe »
measure across the trimmer. it will probably be barely 10v
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
angelodp
Post by angelodp »
Yes 9v, thanks for the info, shoulda known that.
