Output wave form dance.
Post by Stevem »
I took in the Hammond Organ amp conversion ( now a BF Deluxe reverb with added gain stage , but no Choke ) and once I fixed its main issue and got it on the O-scope I see the whole output wave form dancing up and down at whatever frequency I pump into it .
This takes place at any level of output also, from 1/2 watt to its full clipping power of 32 watts.
Anyone here ever seen such before and fixed it?
Tonight I will scope it out starting at the first gain stage to see if this through out the amp.
Thanks in advance for any help.
TUBEDUDE
Re: Output wave form dance.
Post by TUBEDUDE »
I've not seen what you describe before. I've seen outputs modulated with line frequency, but not with the input freq. I'm betting on a circuit ground problem. I assume your scope ground is good. Does the percentage of modulation increase with increased gain?
Schematic?
wpaulvogel
Post by wpaulvogel »
A video clip would help also.
Post by Stevem »
Well I had to get the amp back to owner with that issue taking place as he needed it for recording , so no video can be taken.
That being said just invasion the whole wave form looking like it was riding on another unseen wave form that was running thru it with it and following input signal frequency.
I would have loved to have got it solved but the time was not to be had.
I will likely see the amp again as it has a oversized power transformer and can push out over 30 watts peak and its dinky original output transformer is destined to burn up sooner then later!
sluckey
Post by sluckey »
If the OT secondary was not connected to chassis ground your scope display would dance.
TUBEDUDE
Post by TUBEDUDE »
Sluckey, wouldn't that dance be at the line frequency?
pdf64
Post by pdf64 »
TUBEDUDE wrote: Wed Sep 23, 2020 2:40 pm Sluckey, wouldn't that dance be at the line frequency?
It may be that an incomplete NFB loop (ie from a missing OT secondary 0V connection) might have a weird effect such as that described.
