ISOLATION TRANSFORMER RECOMMENDATIONS FOR RELAY HEATERS
ViperDoc
Post by ViperDoc »
I've been looking around for a 120VAC: 6.3 V auxiliary transformer for isolated relay heaters. One of you mentioned a .6A Hammond but I can't find them in stock. Anyone tried Triad Magnetics, like this one?
https://www.mouser.com/ProductDetail/Tr ... 52BoaQW1Zr
I would ideally like one with a closed housing. I'm still looking, but if you know of one you like, please let me know.
Many thanks!
Just plug it in, man.
ViperDoc
Re: ISOLATION TRANSFORMER RECOMMENDATIONS FOR RELAY HEATERS
Post by ViperDoc »
I found this one:
https://www.jameco.com/z/AC463-1-2-R-Po ... xpEALw_wcB
Anyone used one of these? Thanks.
ViperDoc
Post by ViperDoc »
Here's a hammond with a 115V primary.
https://www.mouser.com/ProductDetail/Ha ... 8G%2FnI%3D
I see the "B" version is 117 VAC on the primary. Would that 2 V make any difference?
https://www.mouser.com/ProductDetail/Ha ... BoYOpRM%3D
Thanks!
PaulD
Post by PaulD »
ViperDoc wrote: Fri Mar 27, 2020 1:07 amI see the "B" version is 117 VAC on the primary. Would that 2 V make any difference?
Easy enough to work out, 6.3 / 117 = 0.05 therefore each volt on the primary equates to 0.05v on the secondary.
