Need Help with a Schematic - Excelsior Americana (Sano)
tubeampkunkie
Post by tubeampkunkie »
Okay, so I need some help reading and putting together a circuit from the schematics below. They show an Excelsior Americana amp that has tremolo on the Treble/Bass (accordion) pre-amp section only, and reverb available to both pre-amp input sections. The amp also keeps the wet reverb from the dry signal, and outputs the wet reverb through a separate power amp and speaker. This gives a wet/dry reverb rig in a single amp. What I need help with is: how/where the pre-amp output (1) connects; how/where the reverb volume pot and foot switch (2 & 3) connects to the reverb amp section (5); how/where the power-amp section connects to the pre-amp section; and, how/where the left reverb input(s) connects (6). The Reverb Input connection was pretty obvious. I've scoured the Internet, and haven't found any real detail of how this goes together. The first PDF shows the power-amp section, and the second PDF shows the pre-amp section. Thanks in advance for your help and insights.
https://www.vintageguitar.com/17184/exc ... americana/
Re: Need Help with a Schematic - Excelsior Americana (Sano)
Post by Stevem »
So you don't have the amp to inspect?
