Delete
				RockinRocket
Re: VOX AC15 Heritage TB channel bleeding into EF86 channel?
Each channel has its own path to the PI. You could try and disconnect the tone stack from the PI entrance to see if the bleed is through the PI.
I vaguely remember having a similar issue with a 18 watt Marshall. Same typical design as the Vox with the PI and I think a 100ohm resistor to ground from one channels tone pots wiper fixed the bleed.
				RockinRocket
Re: Delete
Why delete the thread?
would be nice to know if you have solved the problem ?
