Kiwame Carbon Film Resistors good enough?
Hi. I wonder why it always seem to be Xicon ceramic in the power section. I have a Kiwame Carbon Film Resistors 2.7k 5w, would it be equivalent? (Dumble ODS)
Re: Kiwame Carbon Film Resistors good enough?
Nothing special about Xicon, they are just what is commonly available in ceramic WW here. Any WW or metal oxide resistor would do. Flameproof resistors are best for the power supply, so CF would probably not meet that criteria.
This is the description:
"2K7 Ohm 5 Watt, Kiwame Carbon Film Resistor, 1% Tolerance, Axial, Tinned Copper Leads, Flameproof Silicone Coated"
- norburybrook
Give it a go
simples
M
Several of the OD layouts have PSU resistor wattage way beyond what is necesseary, - e.g. the 270k balancing resistors for the two main cap's are often shown as 5W, but on calculating the dissipation with one cap shorted, one resistor will dissipate appx 1W....
OTOH - better safe than sorry.....
