Encountering a weird phenomenon in my 68 model 1987 plexi build.
Vol drops (but comes right back and dips again) when wailing on E, D, C ext cords in a unusuall vol/EQ settings.
Bright Vol maxed.
Presance Maxed
Treble Maxed
Bass Zero
Middle Zero
If I bring in the mids or bass a bit it goes away with these same settings.
When using the Normal input this doesn't happen.
I have another 68 that is part for part the same except the one in question a different power transformer and has 30 more volts.
So what's going on here is the feedback loop acting up under full load of just top end frequancys?
Vol fade (Not Sag)
Re: Vol fade (Not Sag)
Your description seems to match how blocking distortion is described:
http://www.aikenamps.com/index.php/what ... distortion
Merlin also covers this in his preamp book. The cure seems to be use smaller coupling caps and or larger grid stoppers. It might help to have a scope
to see exactly which stage is affected.
Mike
Mike
What voltage are your coupling caps into the PI and out rated at?
They have a AC rating ( signal level) as well as D.C. , and there AC rating is half the D.C. Rating, or should be .
Some new caps fail in this regard!
RockinRocket
The caps are 400v nos mustards. Used them before with no leakage.
I was thinking it was a feedback loop
