Funkalicious OD Layout/Schematic
Is there a layout and or schematic for the chassis/board set Funkalicious Groove sold some time back?  I think it's finally time for me to put it together.
									Great things happen in a vacuum
						- pompeiisneaks
- Site Admin
Re: Funkalicious OD Layout/Schematic
I did a search and found this thread, where you'd asked the same question a few years back and in it funkalicious groove replies with what you can do:
https://tubeamparchive.com/viewtopic.ph ... ove#p31000
~Phil
~Phil
tUber Nerd!
Barry I'm not exactly sure which boards fit the Funk chassis.
I have one of his chassis too but mine has no silk screening all blank mine needs faceplate plus boards.
I bought 2 and built a bluesmaster in one and 183 in the other.
I believe J Boarders boards were modeled from Funk's. You'll have to check, but probably the eyelet boards I drew up (and Taylor produced) will fit. See in the D Files section. https://tubeamparchive.com/viewtopic.php?f=5&t=29630
Thanks Martin I will check and see if they fit.
