Bright Switch Question
Two bright switches on this build. First seems to cut mids??  Second is a bright shared by the Plexi and 800 circuit. Any idea what the switch between the normal and bright pots is supposed to do?
Re: Bright Switch Question
Why don't you draw that part of the circuit out, it would likely be easy to determine then!
