 The board had been getting on my nerves for a while now with this amp, I like boards just fine on designs were everything's been hammered out but this is a one off kinda prototype-y thing and having to pull the board every time I wanted to get to a jumper or something like that was getting old. In any case here's a few pics documenting what I did:
Amp as it was at the start of the weekend.
Gutted, additional octal socket hole cut out and installed, filaments wired and starting on pre-amp supply.
Terminal Strips installed.
Populated
PS wiring
Pre-Amp Wiring.
Completed Build.
Left some extra slack on the OT secondaries in case I had to reverse them. Got lucky and didn't need to.
Quite pleased with how in came out. I kinda winged it on the layout, just trying to keep to the order components are placed for the pre-amp in Ken's original design. Had to move the cathode circuit of the first gain stage up near the tube socket as I ran out of room. Got it on the test bench, came up on the variac without a hitch, plate voltage is around 375, biased it at 28ma or right around 75%. Plugged it in and it sounds sooooooo much better than it did before. I'm quite happy with it. It still has a bit of that parasitic oscillation sitting on top of certain notes however it sounds so much better than before it was hard for me to care. I realized later that I forgot the cap across the PI plates (and also the bright cap) so I'm hoping that will help. I was quite surprised to see it be completely stable, even with no bottom cover. I thought for sure the first time I fired it up it would be a squealing mess given how mushed together everything is. It does squeal with the guitar volume all the way up and gain cranked but I think that's more due to micro-phonics with regards to the pickups in the cheap shop guitar, I doubt they are potted. Still I'm going to go to the hardware store this week and pick up some sheet metal and make one, that might help with the fizzy oscillations as well. Nonetheless I'm loving the way it sounds, its DAMN loud, I had to run it variac'd down to about 70VAC as it was getting late and I didn't want the neighbors getting pissed. Sure gets nice and chewey and brown down at those voltages, would love to add a VVR but not sure where I'd put the damn thing
 The only reason I ever built it as a SE amp was I didn't think I could squeeze a PP and associated circuitry in there, glad I was able to prove myself wrong. Will get some sound clips up soon.
 The only reason I ever built it as a SE amp was I didn't think I could squeeze a PP and associated circuitry in there, glad I was able to prove myself wrong. Will get some sound clips up soon. Also considering upping the output coupling caps to .1's from .022's but I don't have any more at the moment. Will probably try playing around with longer cables next, the one I've been using is pretty short. Also I'm using a new speaker (Weber 1225) even though I had it broken in I suspect it will probably mellow out more as time goes on.
