Trainwreck Express Sag
- Littlewyan
Does a Trainwreck Express sag under load? I know the voltage across the 1K choke resistor sags a lot but does the actual HT drop at all?
Re: Trainwreck Express Sag
I just measured it at about 8V, or 2%, from zero volume to wide open into a dummy load. Just happened to have it out on the bench ;^)
						- Littlewyan
Ha, brilliant! Thanks Martin. I always thought the HT in an Express was quite stiff but I saw a post from Glen saying his HT sags under load. He didn't say how much though.
Very little sag at the anode but some screens sag and presumably some preamp sag. 300mA PT is alot for a small amp like this (6k6 primary). By comparison, marshall used a PT rated for 290mA with a 1.7k OT primary, something which gives a lot of sag
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
- Littlewyan
Good comparison. Thanks Roe. Those old Marshalls need sag for the valves to survive!
