https://tubeamparchive.com/viewtopic.ph ... hlight=5c1
Here's my 5C1 from a long while back but it might interest you. The way it's built turned out dead quiet, can't even tell it's on, but it's also a low power, low gain amp which has something to do with that, but still no hum even w/ a 12". It's a great little circuit, my tips:
Use the 5F1 power string, no reason not too, the 5C1 string didn't suggest any particular vintage mojo to me and I wanted to use it with speakers bigger than a 6” or 8” so I changed it. But keep the caps pretty low in Champs, I found the looseness helps them sound fatter, it's one of the differences btwn the tweeds and the BFs. I see no point for choke, though I never tried it. I recall a Gerald Weber tweed Champ article saying it brings no goodness. I’ve built several Champs, never any hum problems.
Keep the grid leak input, at least try it out. It's very cool, has that touch sensitive clean to mean as you dig in, even though it's only for a few watts of bite. You can always try cathode bias with a few minutes of work. If you intend to use pedals grid leak won’t do, but one builds a Champ exactly to avoid pedals - it is a distortion pedal.
Use good iron. Allen or Heyboer will make it sound Fendery, Edcor will make it sound real good but not Fendery.
Think about upping the PT by maybe 25V. Mine came out at about 300V, as is correct, but imo it could use an extra watt or two, maybe try for ~360V, unless you really want only a bedroom amp.
I added to mine a pretty cool preamp option, simple line out w/ a load, works well as a PA preamp, I was hoping for a wild tube overdrive feeding an other amp but it actually keeps its modest 5C1 character out the line on the resistor load.
