Finished combo on left:
I am currently using a Scumback M75LD 65 watt 16 Ohm in that combo. It sounds awesome! Very happy with the results....
I clean with 99.99% Alcohol as soon as I finish the joint. Standard AC heaters, I really pay attention to lead dress and ground points.rp wrote:That couldn't have come out any nicer. No flux residue anywhere, so what's your secret?
DC heaters? Did you find you need them or just planned it from the start?
That was a Reinhardt Combo cab I repurposed. I bought it used from a guy who put his into a head format.Guy77 wrote:Awesome build! I really like the 2 tone colour on the combo, green and white really go well together. Was the 2 tone hard to do?
Cheers
Guy
Try acetone, the stuff from the hardware store not nail polish remover, better than alcohol. It does help to remove the flux while it's still warm but I just don't have the patience like I used to, but I do try to clean up the worst when I'm all done.fusionbear wrote:I clean with 99.99% Alcohol as soon as I finish the joint.
What's this in the image?Standard AC heaters, I really pay attention to lead dress and ground points.
That sounds fantastic ! I'm just getting ready to do a very similar build. I may have a question or two for you, if you don't mind.
