 Thanks in advance.
  Thanks in advance.Heater Wires
Heater Wires
Quick question:  Is 22ga solid core large enough for heater wire in this amp?   Thanks in advance.
  Thanks in advance.
						 Thanks in advance.
  Thanks in advance.Re: Heater Wires
http://www.epanorama.net/documents/wiri ... tance.html
Short answer - maybe... You should be ok using it for your preamp tubes, but's I'd use your transformers heater secondaries guage for the power tubes.
Re: Heater Wires
I don't think it is recommended except in the preamp.  As cheap as wire is I wouldn't take the chance.  I use 18 gauge.
						Re: Heater Wires
Interesting and informative link, Doctor02; thanks.  It looks like 22ga has half the current capability of 18ga: wow!
Thanks for the suggestions, Robert.
D
D
