Impedance switch
menger66
Impedance switch
Post by menger66 »
I will this work for a impedance switch? I don't see any rating on the box
pdf64
Re: Impedance switch
Post by pdf64 »
I think that a non-shorting type may be better but as it's unlikely / not recommended to operate it whilst the amp is working, probably doesn't matter.
Not sure if the contacts are adequate for a 100 watter, should be ok for <20 though.
Post by Stevem »
That switch is only rated for 1.5 amps at 28 volts and a 60 watt rms amp will run 2.74 amps into a 8 ohm diver, so no ,I would say do not use it!
menger66
Post by menger66 »
It's for 20watt cathode biased el 84amp
Post by Stevem »
Then your ok current wise .
pdf64
Post by pdf64 »
The current carrying capacity of switch contacts may be much greater than the max current they're rated to switch, eg 5A cf 150mA http://www.lorlin.co.uk/PDF/CK.pdf
I'm a fan of this switch.
I've used it in several builds, including a 100w Dumble.
[img:250:250]https://images.campyent.com/sites/defau ... p-h600.png[/img]
https://www.tubesandmore.com/products/P-H600
rp
Post by rp »
^ + 1 and apparently those are NKK which explains why they look and feel good. So common and reasonable price that I thought they were some cheap generic thing.
https://www.digikey.com/catalog/en/part ... ries/11276
