Thanks for looking.
Now, I've used RCA 12AX7 datasheet found here -
http://web.eecs.umich.edu/~mmccorq/dive ... /12ax7.pdf
Where the absolute max plate dissipation is 1.2W and plate voltage is stated as 330V.
In reality - it will be much lower (with bias point centered around 1mA, see
http://www.aikenamps.com/index.php/desi ... amplifiers.
Now, using other preamp tubes such as 12AT7, 12AU7, 12AY7, 12BZ7, 12AV7 will definitely change the overall picture, but not significantly. Plus, using other type phase inverter, or cathode follower post PI, will change it even more significantly.
At the end of the day the power section is the biggest concern as far as current draw goes and putting like 10-15% above what power section draws in most cases will land you in the ballpark of what your PT should be rated for.
Another point is that different screen grid arrangements, will eventually render different current draw.
With all these factored in, the page will end up like a web version of (LT)Spice
I am not saying it is impossible to design the page so you have more configuration options (and I am all open to listen for what will work for you all), but:
- it will definitely bring up the assumptions level
- will take more time & testing - I am OK to do it (after all this fine community is driven by its members contributions)
As at the moment, I think that it will make more sense to prepare "datasheet" type database to be displayed when a particular tube is selected, as whatever calculations are performed on this particular subject- they are always approximate and datasheet should be referenced.
Niki
EDIT: Meanwhile, the formulae has been added. Just click "Show formulas" for an immediate math experience ...
 Did not manage to find the fancy font, so it is rather ordinary still.
