Small dental brushes - you guys using these ? Works pretty good with a little de-oxit. Scrub then tighten.
But don't forget to drain the caps.
Tube socket contact cleaners
Why Aye Man
Re: Tube socket contact cleaners
That is a great idea. Good for RCAs too I bet.
- David Root
Good stuff Bob! Where do you get them??
Any drug store - almost wrote chemists. A drug store is something different where I come from.
I got these at CVS.
I got these at CVS.
Why Aye Man
- Ron Worley
I love it guys come up with cool new tools and ways to do stuff!
Ron
- Leo_Gnardo
Got some of the straight-handle ones a year or so back, good cleaning tool. Besides the ergonomic handle, is yours motorized like modern toothbrushes?Bob S wrote:Small dental brushes - you guys using these ? Works pretty good with a little de-oxit. Scrub then tighten.
I have used pipe cleaners but they are a bit wimpy.
The downlow cheap way is to use a cut off section of a round wound string with the needed OD to just expand the tube socket reciver pin a bit as you scrub it in and out, and yes drain the power supply which can be done easy if the amp has a standby switch that you can flip on with the mains switch off of course!
