I just want to make sure I'm doing this right.
I'm replacing the OT in a '65 Bassman(sheet says AA165 but circuit is AB165).
The reversed secondaries, to make the wacky NFB work, has totally thrown me for a loop. Reason being, owner wants me to wire 1 speaker jack as 8ohm, and the ext. as 4 ohm.
I've already installed non-shorting jacks. I'm using MC 40-18009. So I was going to wire the black common wire to the tip, and jumper over to the tip of the other jack. So for the 4 and 8ohm leads, I was going to wire one to the sleeve of one jack, and one to the sleeve of the other.
This would keep with the original "backwards" wiring. However, since the sleeves have continuity through the chassis, it's like the 4 and 8 taps are connected.
This is blowing my mind a little bit. But, since the all the leads' duties are reversed, this should be fine, correct?
AB165 OT wiring
Re: AB165 OT wiring
Use the common on the secondary as intended, ground it, and use separate jacks for the 4 and 8 ohm taps. Now all you have to do is flip the primary leads.
Smokebreak
Re: AB165 OT wiring
Ok thanks Martin, and the NFB can come off of the 4ohm tap now instead of the common? I'll need to move that.
Sidenote: one of the screen resistors wasn't soldered in. Looks like it never was. It was barely hanging on, too. Owner reported zero problems.
edit: I meant to ask if the NFB stays on the tip, as now the 4ohm tap is there.
Re: AB165 OT wiring
Yes, correct, if you want the same level of NFB. You have an option now with the 8-ohm tap too.Smokebreak wrote:edit: I meant to ask if the NFB stays on the tip, as now the 4ohm tap is there.
Smokebreak
Re: AB165 OT wiring
Thanks again Martin, it all worked out.
