4x6V6 output transformer
- turbo5speed
Hi,
I know this as been discussed before but i need a little more help on finding a suitable output transformer that can handle 410V on the plates of 4x6V6's.
I was looking into the Hammond 1760J but i don't believe it can handle such voltages.
The tubes are JJ's 6V6S that have a 500V max plate voltage and are 14 watt power.
I had a transformer custom made that shorted to ground after 30 mins of loud playing...
There is also the 1750N but i don't like the primary impedance wich should be around 4K.
Some advice please? I live in Europe so i prefer something i can buy here.
Thank you!
Thank you!
Re: 4x6V6 output transformer
1650N, 1760K, 1760L, 1760M.
						- turbo5speed
Thanks. Wasn't aware of those models. Can you give me some non Hammond options?
Like I said in the other thread of the same topic, a Dynaclone A-470 will handle all you ask of it and provide excellent bandwidth if you're willing to shell out the dough. 4.3k primary. Or check the Bay for a used, vintage piece. They're mostly sold in pairs though.
InMadOut transformers from Italy.
Drop an email to Savino and he'll set you up. They do custom ones as well.
Niki
Niki
typical fender bandmaster or super reverb output transformer. jtm45 transformer. hot rod deluxe output transformer.?
									Congress Park Amps
Dynaco A470 is an excellent choice. Bassman too.Blackburn wrote:Like I said in the other thread of the same topic, a Dynaclone A-470 will handle all you ask of it and provide excellent bandwidth if you're willing to shell out the dough. 4.3k primary. Or check the Bay for a used, vintage piece. They're mostly sold in pairs though.
I have used 50 watt Marshall iron on several 4X6V6 amps and have never been disappointed with the final outcome.
Should be easy for you to source.
Regards
Randy
Regards
Randy
- turbo5speed
Thank you all for your sugestions, it is much appreciated! I will report back with the results regardless of OT choice.
Hugs!
						Hugs!
Check out the Heyboer-designed Allen TO40MT:
http://www.allenamps.com/parts.php#transformers
- oh, wait - Allen won't ship to Europe. Never mind....
Mercury magnetics makes a clone of an old Jim Kelley 4x6V6 OT.
I think it's called the: JIMK-O
The amp I played it in was a Fargen Blackface style amplifier and I thought it sounded very good.
good luck!
P.
good luck!
P.
				gingertube
Likewise - I used a JTM45 (Raa = 3K4) 50W marshall OT with a quad of vintage 6V6G. VERY happy with the result.RB wrote:I have used 50 watt Marshall iron on several 4X6V6 amps and have never been disappointed with the final outcome.
Regards
Randy
Ian
- turbo5speed
Hi,
Ended up buying a very high quality 50 Watt / 4Kohm OT with M5 grain oriented laminations that Geoff from Matamp had.
I tested the transformer on the bench and all the impedances/winding ratios of the 4, 8 and 16ohm secondaries are spot on.
Excellent sounding transformer i should say.
Thx again for all the help!
Cheers.
Cheers.
- turbo5speed
btw... i have JJ's 6V6S with 422V on the plates. The JJ's are 500V max so i'm ok. Other manufacturers have much lower limits.
Anyone ever tried other brands of 6V6's with such high (or even higher) plate voltages with good results?
