The Pin 3 plate voltage is 315 volts, pin 4 screen voltage 0, this is the same for both 6v6 tubes. Should there not be voltage on pin 4? I have traced all the wires repeatedly and still amp does not function. Been learning expieriance but would appreciate help
Thank you
BYOC Tweed Royal kit problems
Re: BYOC Tweed Royal kit problems
Yes, screen voltage should be near 315, same as plates or a little lower. Pull the tubes while you're figuring this out. Screen resistors burnt? B+ getting to screen resistors?
Thank you, oulling out tubes. Cathode pin 8 at 0 dc, pin 5 control grid at 1.4 and 1.3, .
Thank you
Thank you
Did you wire your 220k resistors under the board like the instructions say to pin 6 through a 1k5 resistor to pin 5? Make sure all connections are good
Thanks for the help, broke solder jt putting board in chassis
