Belden + 450 VW -1 wire
I have some coax Belden wire. It has the wrap type shielding with drain ( ground ) wire. Its carrying two signal wires .64mm each. Would this wire be useful as coax for amp work.
Re: Belden + 450 VW -1 wire
If you have a meter that will measure small capacitance, you can cut a foot of it, short one end and measure the capacitance at the open end between conductors.
what would constitute a good reading
Hi Tom, what am I shooting for as an acceptable reading?
I would say that below 30pf it can become brighter sounding.
Average instrument cable is generally higher than 40pf or higher.
But it may be a good thing as well if the amp is bright.
Mogami W2524 cable is 39.7pf/ ft.
Mogami W2319 cable is 47.3pf/ ft.
http://www.mogamicable.com/category/bulk/guitar/
tele_player
Shorting one end seems incorrect to me, and doesn't work with my cap meter. On the other hand, not shorting one end gives me expected readings.Structo wrote:If you have a meter that will measure small capacitance, you can cut a foot of it, short one end and measure the capacitance at the open end between conductors.
Robert
I don't see how a shorted capacitor can exhibited any capacitance?
Pretty much any shorted component become a short.
