new build #40 - question about 180k resistor in OD section
dinkotom
Post by dinkotom »
Forgive the probably silly question. By mistake I soldered 180K resistor to the OD2 cathode and not to ground (long story :roll: ), and the amp still sounds good. Just for curiosity I'd like to know what does it do to the circuit if it's connected that way?
Here's the original schem, just imagine that 180K is on the OD2 cathode:
https://tubeamparchive.com/download/file.php?id=24300
ODwan
Re: new build #40 - question about 180k resistor in OD section
Post by ODwan »
When no signal is present, the cathode sits at a low positive voltage (1-2 Volts). Shouldn't do much, though.
For signals the cathode is at AC ground for all but very low frequencies. I would correct it anyway, just to have it correct.
Greetings,
Timo
dinkotom
Post by dinkotom »
Thanks!
dinkotom
sound clip
Post by dinkotom »
here's the sound with Supro lap:
https://www.youtube.com/watch?v=Q0-c_j7_ftk
