This is a simple 16 dB amp attenuator I built using an L-pad attenuation calculator and some parts I got off ebay, and a little chassis box I made...
Marketing says hold on to this, so...
													Brick Out house 16 dB attenuator
						Re: Brick Out house 16 dB attenuator
That's pretty cool. Would you mind posting the schematic? And where did you get that resistor?
I built a low wattage attenuator in a coffee can, check it out:
Ampwell House Attenuator
Never try to teach a pig to sing. It wastes your time and annoys the pig.
