I'm just trying to confirm something that I believe is true about transformers. If I have a transformer with a 230V Primary and a 18V Secondary that can supply 2A, would I be right in saying that the 2A on the Secondary would be seen as maybe 100mA on the Primary?
Then for say a 230V Primary and 600V Secondary Transformer, 150mA on the Secondary is seen as 1A on the Primary? The numbers used are only examples btw.
Transformers and Current
Re: Transformers and Current
The amperage change is in direct proportion to the turns ratio!
For an ideal transformer, the ratio of primary to secondary current is inversely proportional to the voltage ratio, i.e. Vs/Vp = Ip/Is.
For your first example, 18/230 = Ip/2, Ip = 0.157A
For your second example, 600/230 = Ip/0.150, Ip = 0.391A
- Littlewyan
Fantastic! Thanks for that.
