Ashdown Bass
Ashdown Bass
Got two Ashdown EVOII Bass Magnifier amps on the bench. One is Chinese built. Both have hum issues. This one in photo has broken B100K pot so need to find one of those spider types or at least pcb type if nothing else.
The large filter caps are 4700uf/100v and probably should be replaced after all the use it has had. There are two 22uf/450 caps near it as well.
Very dirty, dusty and loose bolts/screws every where. No ground lift on Line out either.
Re: Ashdown Bass
Post by Stevem »
Getting what you pay for has never been truer of China made stuff !
