power switch for SE
angelodp
power switch for SE
Post by angelodp »
I am building an SE amp from available parts and I am planning a 120v panel light ( space reasons ). The switch I have is an Und. Lab part DPDT ON/ON. It has the six tabs in the back. Its rated at 6A 125v. The Panel light will be on the power switch in parallel. Its a neon RS type with built in resistor. I will only use the top part of the switch so its effectively going to be an on/off switch. This make sense to use.
Re: power switch for SE
Post by Stevem »
It will work fine, when the switch is in the down position the amp will be on and the other side will be zip!
tele_player
Post by tele_player »
angelodp wrote:I am building an SE amp from available parts and I am planning a 120v panel light ( space reasons ). The switch I have is an Und. Lab part DPST ON/ON. It has the six tabs in the back. Its rated at 6A 125v. The Panel light will be on the power switch in parallel. Its a neon RS type with built in resistor. I will only use the top part of the switch so its effectively going to be an on/off switch. This make sense to use.
FYI: that's DPDT
angelodp
Corrected
Post by angelodp »
Yes thats true DPDT… I'll correct that
