treble peak>coupling cap or coupling cap>treble peak??
sonofmickel
Post by sonofmickel »
On the "sean superdrive601" schematic there is a 470p/560k>100K>.0022 that runs off the Plate on the second gain stage. The "Naked" schem and the dated 083096 have a .002 coupling cap>500k volume(100p treble cap).
My question is what is happening theory wise when the order is reversed(like Marshall)?
Coupling>Peak vs Peak>Coupling?
I am going to try it and draw my own layman's conclusions.
tubeswell
Re: treble peak>coupling cap or coupling cap>treble pe
Post by tubeswell »
sonofmickel wrote:On the "sean superdrive601" schematic there is a 470p/560k>100K>.0022 that runs off the Plate on the second gain stage. The "Naked" schem and the dated 083096 have a .002 coupling cap>500k volume(100p treble cap).
Sean Superoverdrive schemtaic
[img:1024:727]http://i176.photobucket.com/albums/w197 ... ive601.jpg[/img]
560k||470pF is a hi-pass filter. In terms of AC load, the 560k is also in series with 100k and then 500kA||1M. So the 560k is part of an AC voltage divider which is attenuating the signal from V1a in that regard. The .0022uF is a coupling cap.
In the other schematic, the .002uF coping cap comes straight off the plate and the 500kA pot is the variable voltage divider which is bypassed by a 100pF bright cap that only works when the pot isn't at full CW rotation.
sonofmickel
Re: treble peak>coupling cap or coupling cap>treble peak??
Thanks tubeswell,
But what happens to the signal physically? Does using a coupling cap before a treble peaking circuit offer protection to the user? Does it provide a less-bass to the treble peaker than a treble peaker feeding a coupling cap? What signal actually has less bass being fed to the 500k volume pot? Is it just additive inverse, same either way? Does one pass less signal?
sonofmickel
OK, first test was to add in the 470p/470k treble peak after a .002 coupling cap from the second stage plate. = instant hot rod marshall, it lost most of the bottom chewieness and added too much treble to the signal. I might try a 250p/250k? Would the 250p/250k cut a little less lows and add just a little more zing? That will be my next test tomorrow, or maybe tonight.
