Silver Mica w/ EM on it
angelodp
Post by angelodp »
Hi, I have a stash of silver mica caps - 250pf has a 10% EM on it.
Looks good any way of knowing the rating for these voltage wise?
ApexJr.
Re: Silver Mica w/ EM on it
Post by ApexJr. »
The EM is only the manufacturer - Elmenco
There are 4 types of silver mica's
Commercial - DM 05, DM 10, DM 15, and DM 19
Military would be the same except CM and if military it would
be on the part CM15 251K
You'll need to look up these numbers on the internet and go by
the sizes to get your rated voltages.
angelodp
EM
Post by angelodp »
Thanks Steve, all I see on here is EM 250 +- 10% no other codes??
Ange
gui_tarzan
Post by gui_tarzan »
A capacitor reference chart says that 250 = 25pf.
--Jim
angelodp
cap meter
Post by angelodp »
My cap meter shows 250pf
angelodp
EM
Post by angelodp »
EM appears to stand foe El Menco and they are Vintage, or so some articles say.
tubeswell
Post by tubeswell »
Get a 1000V variac, wire the cap in series with a 10W 150R resistor (for fail-safety to protect your variac), and clamp a 15V decent rated power zener in parallel with the resistor. Hook the variac up across the cap and resistor in series. Now start winding the voltage up, whilst measuring the voltage drop across the cap. If you get to 450V and it still doesn't short, I'd say it'd be good for 500V. If it does short, it was never gonna be any good for a tube amp anyway.
ToneMerc
Re: EM
Post by ToneMerc »
angelodp wrote:EM appears to stand foe El Menco and they are Vintage, or so some articles say.
EM stands for the Electro Motive company and their brand was El Menco. They made great caps, the film caps were licensed using the original Sprague 6PS dielectric forumla and the dipped silver micas are great caps too. I usually will use the older EM and CD dipped silver micas over any of the modern stuff.
Do you have any pictues or measurements? I can give you an estimate ofthe voltage ratings.
TM
ApexJr.
Post by ApexJr. »
Here are the 4 different sizes, I should have done this first
since I have stock.
angelodp
120pf
Post by angelodp »
Hi, Here is a shot of one of caps. Any idea on voltage rating for this?
thanks
[IMG:1024:768]http://i260.photobucket.com/albums/ii9/angelodp1/IMG_0372_zpsf570cf80.jpg[/img]
ApexJr.
Post by ApexJr. »
This looks like a DM15- CM05 so rated at 500V
angelodp
great info
Post by angelodp »
thanks for that.
angelodp
this guy
Post by angelodp »
ApexJr.
Post by ApexJr. »
Yes, those too look like the DM 15 type rated at the 500V
