 I was playing my EF86 Special and wondered what might I like more than the recent build. I listened the old sound clips of the EL84hrm and thought I might build it this time with a better layout. I used 10thtx's layout for starting point (Thanks Jeff!).
 I was playing my EF86 Special and wondered what might I like more than the recent build. I listened the old sound clips of the EL84hrm and thought I might build it this time with a better layout. I used 10thtx's layout for starting point (Thanks Jeff!). I took the EF86 Special apart- took about 20 minutes. Then built SE EL84hrm again- took several hours during two days. It was an junk box build. I used partly used but quality parts and wire that was left. Then tweaked it for four days and went to rehearsals to record a sound clip.
I had noise problem when artificial heater center tap (2 x 100R) was connected to cathode of the EL84. Moving it to ground everything was noiseless.
The recording setup was ES339 to EL84hrm with a DIY tube reverb on the passive loop (the reverb unit smoothed the sound really good). SM57 on grille and SM58 about one meter from grille. Cab was 2 x 12'' with only Eminence Delta 12A pro connected. Added reverb and delay on the Reaper recording software.
The amp has a switch to bypass the HRM (BIG BOOST) and other side of the switch connects 10k to 1M pot to ground to adjust the boost. It also has switch to add local feedback loop to V2a (or b, don't remember, am at summerhouse). Normal boost and mid boost and bright switches are included.
The tube reverb is essential on the loop to get good sound. I would like to know if someone has suggestion for a hi frequency leak to be connected on the switching jacks of the loop.
I'm going to test the amp with other speakers for the delta pro being so chimeless. The Eminence Legend EM12A seems promising.
The two songs are total nonsense, but I think they will present the amps sound quite nicely.
Be aware, my builds are usually very ugly
 picks: https://www.flickr.com/photos/fuzzface1 ... 469577421/
Be aware, my playings are usually very ugly
 soundclips:https://soundcloud.com/ef86special/2014 ... /seel84hrm
  Love the sound and playing.
