Hey guys I have a JTM 60 combo here with low volume otherwise sounds and functions fine.
I have cleaned all the pots, switches and tube sockets.  Tested tubes, checked voltages here they are.
(V1 12ax7) (V2 12ax7) (V3 12ax7) (V4 12ax7)
1    172           190            328             249
2                                      169               30
3     1.4            1.4            172               44
4    -3.6           -3.6           -3.6             -3.6
5    -3.6           -3.6           -3.6             -3.6
6    198            160           169
7                                                          28
8     1.6            2.1            1.5                44
9     3.6            3.6            3.6                3.6
(V5 EL34)     (V6 EL34)
1
2
3   484              484
4   476              476
5   -36               -38
6
7
8
Any ideas?
B
						JTM60 1-12" combo low volume issue
				bastardbus
Re: JTM60 1-12" combo low volume issue
If the amp has effects loop in and out jacks poke a plug in and out of each  5 to 8 times and see if the signal level comes back up to normal.
Did you swap preamp tubes around to see if it changes the issue or better or worse?
				bastardbus
Yup did that like 20 times. Left that jumpers in place and indeed you can tell the jacks seem to be are working fine but still low volume. I also cleaned all the jacks and pots with CRC then deoxit. Do these jacks just need cleaning or can they go completely BAD?Stevem wrote:If the amp has effects loop in and out jacks poke a plug in and out of each 5 to 8 times and see if the signal level comes back up to normal.
Swapped pre amp tubes all over and tested them all as well and were fine. Even swapped in new tubes in pre amp section.
I used the effects loop send and ran the pre amp into a hot rod deville and she sounded great. So pretty sure the pre amp section is good. I think it is somewhere in the output section. I tried sending the pre amp of the deville into the return of the Marshall and NOTHING...silent. BUT if I jumper the Marshall send to return it works fine.
BTW looks like the forum screwed up my voltage chart I made. I will re do that...
I suggest deoxit ALL the ribbon cable connectors.
I have a 212 model. It made a difference.
Good luck,
Denny
Good luck,
Denny
				bastardbus
did that too, thanks though.
can you re post the voltage test out and a schematic ?
- CarolinaGearHead
Maybe bad solder joints? I've got a JTM60 and love it. Good luck and keep us posted.Greg
