I just performed my first simple mode on my VHT Special 6 Ultra. I added a Hammond 157M choke per Rob Robinette's website. It involved merely removing R43 and soldering the leads of the choke there. The mod itself got rid of almost all of my high gain noise(Ultra channel). Then, while tweaking my tone as I played, I noticed that I no longer had a functional Wattage control. The "effect" is "stuck" at the full wattage position. 3 wires lead away from the Wattage pot(red, brown, black). I have checked the continuity of all three, and I get just a few Ohms on each wire. The black wire does lead to one of my choke lead connections, but as i said, it checks out. Visual inspection had turned up no loose connections, bad looking solder, or burned spots.
I am not the best troubleshooter, especially when I can't hardly read the VHT schematic, cause it's so darned small print wise. So, I'm asking anyone who might be able to check this problem out, to let me know what I might check. I'm afraid that I don't know how to leave a quick link to the schematic. However, one can search VHT Amplification - Special 6 Ultra. Then click on manual, and go to page 15. I truly appreciate any help anyone may offer here. I have emailed VHT, but it may be days or weeks before I get an answer from them, IF I do.
Sincerely, tonequester
