Music Man 212RD
wildeman
Music Man 212RD
Post by wildeman »
Just got this burned up MM from a friend. Think this is gonna be my next restoration project. Wonder if someone can send me some high resulution pics from the same type amp. I can't find them on them on the internet.
Re: Music Man 212RD
Post by Stevem »
These amps output stage are baised in class B and run a high B+ voltage which is something I would change about the amp if the PT turns out to be toast!
The Zener regulator diodes in the SS power supply section fail all the time is these amps also and the full voltage can take out some of the semi conductors, so unhook the PT wires to that feed that whole SS section and get the tube end of it up and running first.
Sorry sometimes I take gut shots of amps I have worked on for reference, but not that guy.
beasleybodyshop
Re: Music Man 212RD
Post by beasleybodyshop »
What about building something else into it?
Super Reverb? Dumble?
Good luck with your project!
TUBEDUDE
Re: Music Man 212RD
Post by TUBEDUDE »
+1 on the build something else on that chassis. That thing looks like it spent time on the bottom of the ocean. Maybe it's the resolution of the image, but it appears to need a sandblasting.
Re: Music Man 212RD
LOL, I was going to say to hose it down with soap and water and then dry it with a fan or a hair dryer. Maybe it's just lo-res.
eniam rognab
Re: Music Man 212RD
Post by eniam rognab »
i inherited an RD50 110 back when i only played acoustically
that amp is the reason i fell in love with amps and tubes and electronics in general really! do right by her please! i loooooooove them!!
beasleybodyshop
Re: Music Man 212RD
Looks like that thing has been through the dust bowl :D
