Plate Supply Wire Routing
Charlie Wilson
I am working on my first Dumble build and I am wondering about the preamp plate supply wire routing. Should they be high and tight under the board with the shielded cables running underneath or down low against the chassis with the shielded cables going over the top? I thought I could figure this out by staring at pictures of other peoples builds but I can't.
Re: Plate Supply Wire Routing
Mine are high and tight. Some 124ish pics on pg 3 of this thread that might help you out: https://tubeamparchive.com/viewtopic.ph ... highlight=
Charlie Wilson
Thanks Martin. I actually have one of the photos of your build as a background on my computer desk top.
